How many batteries for 4000 watts
I wish the 70's weren't so **** big tho...I gotta fit a 7.5 cubed box, 3 amps,and 4 batteries, all below the window line in a escape, that should be fun.....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
when I'm looking at a bettery what should I mainly be looking at....the amperage rating on them....if so then about how many should I need. I'm thinking 2 of the big mofo's or 4 of the 70's
yeah I have been thinking bout wire too...prolly go with some knokoncepts...60 feet if I am lucky...
..Do you think a run of pos/neg from the main battery will be enough, or should I go 2 runs, and do I have to make the ground that long also
I've seen welding wire...but don't want to co chincy on anything. What do you think I will need, thanks guys.
co chinky? I have 3/0 Gauge welding wire and it looks and feels alot like audio wire. I mean 99% ofc coper wire is 99% ofc coper wire...as long as its not tinned you will be fine
If it were my set up, considering the amp has two sets of pos. and neg. terminals, I would do two runs of 1/0 with 200 amp fusing on each pos. run.
A Run of each then....do you think the neg has to be ran all the way from the front, or can I just ground it at the chassy and save myself 30'.
....I will look at some welding wire too
My bad man...I meant go chincy...like go a cheap way, but if it will still dot he same job then I will do it, don't want to sacrifice anything really
da box king
da box king
Portland, MI
da box king
