how is Pyle pro audio
Why do you need that power? Have you ever heard a well positioned 250w?
lmao... I have a well positioned 75 watt that shakes my whole house. (It's a 3 bed 2 bath regular sized house, and when I turn it up, just half way, the windows in my living room shake.
ok and what kind of electrical upgrade are needed? i mean, dryers are around 1600-2000
120v x 15 = 1800 watts
120v x 20 = 2400 watts
120v x 30 = 3600 watts
120v x 50 = 6000 watts
These are the most common breakers in your house. Most likely your wall outlet is the 15 ampere one. You should check your circuit box. That means out of that one breaker (it could have quite a few receptacles per breaker) can handle 1800 watts before it switches.
The most you'll have to do is run a bigger AWG wire from the circuit box and use a bigger breaker. But you should hire an electrician to do that for you.
Don't buy a dayton plate amp. I have the 240w one and its nice if you want a clean looking audiophile type subwoofer but if you want to get loud and probably sound better, buy a behringer ep2500 for $250. 2400 watts rms at 4 ohm. You run them on rca to 1/4" (microphone input style) cable or on rca to xlr cable. You would want to run a receiver as a preamplifier to get more signal voltage, not a big deal. Use the sub out on the receiver to y splitter to rca to 1/4" plug.
Hometheatershack.com has been using these things for a long long time to run their HT subs.
the dayton plate amps are very sensitive to bad grounds. Great thing about the b ehringer is that what behringer did was steal a classic QSC amp design and then sell it for half the price. It is virtually the same amp as the QSC rmx 2450.
Great website, they have good deals on it.
why would you ask do you need that much power.......
fallen has a vid of his ed190.v2 doing 140's 1 meter from the horn mouth off 1krms. that is loud as balls, and it did it relativly flat from like 33-70hz. can you say noise violation? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
anywho i do like the look of that beringer ep2500.... anyone wana give more info on it, personal experiences?
why would you ask do you need that much power.......fallen has a vid of his ed190.v2 doing 140's 1 meter from the horn mouth off 1krms. that is loud as balls, and it did it relativly flat from like 33-70hz. can you say noise violation? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I don't have a personal experience... but it has a .1%THD. From what I've read on home audio stuff, that's pretty high.
someone earlier mentioned BASH plate amps, from what I read on them about a year ago they are the same ones Klipsch uses in their HT subs that cost a shitload of money.
I had a 300w bash running 2 dvc4 cvr 12's for my HT and it was extremely loud. wish I had it still lolz
$2500usd for all three Shipping and PayPal fees extra I have a few BNIB pro series in stock I'm moving. These 3 listed is a full 3way system...
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that...
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
dvrmstrng
dvrmstrng
DE
ballstothewall
