How I should wire these subs
CodyDaGoat
6
OR
I'm wiring to 1 ohm for my subs. My amp powers 1200w RMS X 1. I have two 750w mrs sundown sa-15s
My question is wiring to the amp. It's a monoblock. I has two positives and two negatives. I have two subs, but the box I have makes it so that the subs are bridged on the inside of the box. Only one positive and one negative runs from the box to the amp.
Should I take these wires and bridge them to both positives and both negatives? It's probably a dumb question that I should know, but would I do that or will I get more power if I just wire it into one positive and one negative?
I have two subs but they are bridged on the inside
One positive and one negative come out of the box total
Do I put them into just one positive and one negative omg he amp or do I bridge it on the amp so that I'm using both positives and negatives
I have two subs but they are bridged on the insideOne positive and one negative come out of the box total
U need to figure out if you have d2 or d4 woofers.... then type woofer wiring wizard into google and pick what OHM woofers you have and wire them up just like the picture.
This. You might be limited on amp power depending upon dvc impedance.
CodyDaGoat
CodyDaGoat
OR
Boomin_tahoe
Mike Mccabe
