how high do you guys turn up the volume for a demo?
newb
Mainly owners of Eclipse HU's and Alpine HU's. In my daily driver which has the Eclipse HU, Im scared of going close to 50, I think 80's max. And on the weekend car, which has the Alpine HU, Im scared to go over 18/19, I think 30's max.
i max out on my deck to showoff. if the audiences' impressions arent how i want them to be, i max my gains all out. that should do the trick.
in all seriousness, just go with whatever you feel safe with.
I turn it up to were I have my gains set. On the Eclipse deck that's at 60. I have an 8053 btw, which is for sale //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
i turn my gain to max cuz i use that as the volume
uh, not a good idea....gain is supposed to be set at a certain level, and you use your radios volume control to turn things up.....turn up the gain too much and you're gonna blow some speakers.
btw, my gain is set about at 1/4 . I turn the volume up all the way, then if thats not enough, my radio has sliders for bass and treble...I turn the bass one up all the way.
lol, thanks
meh, my deck does not have the gay numbers like 1-30 volume
mine reads db level //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I use the same volume for a demo that I use when I drive around. I set my gains for 70/80 on Eclipse 8445.
The max volume you should use directly relates to how you have your gains set.
Not that it matters since all these ratings are pretty relative, but I use 5 bellow max of 35. My HU puts out max preamp voltage at max volume, there is no clipping from the HU per tests.
Azbass, grats on the db volume control, means **** //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I use whatever is going to sound the best per song, honestly. I have a bass restoration unit, features on the HU that effect the preamp voltage, and features on the amp that also play a part. Giving any specific number would be pointless.
Pzaully
You are an idiot.
Triple FTW.
nG
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
220
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
804
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
694
newb
newb
los angles, ca
Ku-sama
    May 31, 2024
    May 24, 2024
