How does a sub freeze up?
Supergumby5000
Project: F350 begins...
8,560
Pullman, WA
I just put my sub box into my truck, and noticed that one of the subs is frozen.... no movement in the cone at all.
Never seen power, only been touched to mount into the box.
I am guessing that this is due to the coil not being lined up or too tight? Could that be done in shipping.
Perdy confused right now.... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Most of the time the coil will unwind due to the glue melting down. Then the coil binds up against the pole piece and motor. Also a shifted magnet if the gaps were tight to begin with can do this as in your case.
put 10k on it for burps, see if it moves
only reason i say that was cuz this happened to a friend of mine, it seized up and i wanted to see if 10k watts would get it back in-line... never tried it or seen it done so im curious
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
166
841
10
861
Supergumby5000
Supergumby5000
Pullman, WA
TKCARAUDIO
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
