how do you wire up an xra batt?
bamaboy
War Eagle!!!
i picked up an yellow top, i have 1/0 wire ran from the front battery to a distro block(has 2 1/0 inputs 3 4ga outputs) could i run a 4ga wire to the distro block and connect it to an batt, then ground the battery where i grouneded all my amps? 4ga will be good enough right? it will just run a couple feet to the distro block
I would personaly take the distro off of the setup from the first bat. Run the wirer from the first bat to the second, then off the second do the distro run the 1/0 to the bat and off the second bat run the 4 to the distro.
yea thats what i plan on doing when i get some crimp rings for it but without them would it work like above? i might can fit the 1/0 into the little terminals and screw it down to it
they ordered the wrong one when i told him yellow top he said he took a red top and scanned it to see information on it and he said the yellow top would be here the next day i go in and he f-in ordered another red top so i just picked up a blue top d34 and went with it
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
bamaboy
