How do you Strap two IA 40.1's together
Im sure its the same as every other Zenon amp so if you know how to do a amp made by Zenon could u tell me how its done.. Thanks
negative speaker output to negative speaker output
rca BR OUT on master amp (will have 3 RCA's total) to RCA BR IN on slave amp
one posi amp to sub+, and other posi amp to sub -
there you go
I have 2 20.1s strapped now, and thats how they are hooked up.
So two RCA's into master amp from CD Player Then a single RCA out of master amp to the slave amp.. Then Negative speaker Terminal on master to Negative Speaker terminal on Slave. Then Positive wire from master to Positive on sub then Positive wire on slave amp to negative on sub...
When I strap the amps together I know the master amp runs the slave amp.. SO should I just turn everything on the Slave amp down to 0 ??? I mean like the gain and the subsonic filter and all the other knobs??? Please help thanks
yes turn the slave amp all down to ZERO. If you blow one of your amps ill buy it!!! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Man im full of jokes today!
Did i tell you that I sanded all the glue and coating off your coil on that sub I reconed for ya? So the first time you crank it up ...BOOM:crying:... No im full of jokes today...//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
ha ha ha ha!!!
Korn4Life
SUB LOVE
Korn4Life
PA
x2o
