How do YOU secure your box?
lol well i usually had problems like this too..until just recently
i took 3 pieces of 1/8" steel and cut them so they would be an appropriate length. Attached one behind each seat (where it locks in place) and one to a metal bolt underneath the carpet...hasnt moved an inch since
I always bolt my enclosures right to the floor
either bolts thru the bottom of the box with
big washers on the bolts or I build a brackets
out of angle Iron ..one for each side and bolt
it down...
I welded big flat wing bolts to the floor on my last
install and used big 3/8 allan head bolts to bolt
all 4 corners (angle iron brackets) down
if I can find a pic I'll post it
here are the brackets for my last install
the angle Iron went 1/2 way up the rear of the enclosure
and the enclosure sat in it like rails..each corner had a 2"
tab off the end bolted to the floor...
I could lock up the brakes and not have to worry about wearing it
I know it's phsyco looking...the guys at Car Tunes and Toys nick named
it Frankenports....
blacksatsc2
blacksatsc2
Detroit
THUMPPER
michigan born
    May 14, 2026
michigan born
    May 14, 2026
