how do you know which box is better for a spec sub?
mike_cy
CY
Is there a way to tell if your sub will play better in a sealed ported or bandpass box?
I have 2 10'' Tremor subs
Having the one in a ported at the momment...... it shakes the car, glass but not me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The specs if they help any
Fs = 28Hz
Qms 4,726
Qes 0.483
Qts 0.438
Vas 1,6 Ft 44L
Xmax 0.5''
85db 1w/1m
Revc 6.3MH @ 1 kHz
Single Voice coil 8ohms
(http://www.earthquakesound.com tremor 10'' old model)
don't know if this is true... sealed is for rock? bandpass to hear you a block away?
I like trance if it helps in the decision....
At the descr off them it says "push-pull" configuration but there was no information about it when I bought it. Couldn't find any info on the net either.
I run it with PH300.1 (Brand: Earthquake i know that noone knows the brand //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Im not an expert on the subject but in my opinion if you looking for the loud thump of the techno trance sound your going to want a ported box that your sub is designed for, you will get a deeper bass sound that will not be as tight as a sealed box. A sealed box will give a you tighter bass sound that is not as loose as the ported, in a ported enclosure the sub will not respond as quick as a sub in a sealed box.
mike_cy
mike_cy
CY
mike_cy
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
