HOw do you know when your amp is clipping?
well this ***** how am i suppose to see the amp clip to fix it if the amp is in my trunk?
it is possible to send an amp a clipped signal, that will be indicated by the clip light on the transmitter, or the input clip light on the amp. then on the other hand, it is possible for the amp to receive a clean signal fromt he head unit, then the amp itself clips the signal, which is indicated by the clip light in the output section of the amp.
my hifonics zx1000 doesnt have a clipping light it only has protect....will the protect light tell me if it is clipping??
No. Your protect light will come on when something is wrong and the amp is trying to protect itself i.e. wired too low, amp is too hot, low voltage, etc.
when the lower sounds of the music become louder and have a buzzin sound, that is clipping //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
wrong. totally wrong. clipping essentially is a DC signal being sent to the speaker. so if you think about it, it is like a speaker is holding that note for extended periods of time building up heat, which is how it kills speakers. thats kind of the laymans terms, but you get the idea. its taking a ac sine wave and flatening out the peaks, to create a square wave.
Okay thanks! That was the answer i was looking for. Btw what is the best audio format i should export/listen to? Im trying to rebass by my own so...
It's very likely this has to do with box rise and the fact that you should test for clipping along the entire frequency range that the sub plays...
174
  • Locked
413
Amp
375
trunks9_us
trunks9_us
college station tx
05fronty
    May 20, 2024
    May 20, 2024
