How do you guys cut and remove sheathing on 4GA wire and larger?
I use diagonal cutters to cut the jacket all the way around the jacket, and if I need to cut all the way thru, I just take my time and cut a section at a time..only takes a few seconds to do either
Hot knife would probably be the best idea if you were super serious about your wire size like a few people on here are. But I just use a razor blade knife. I always have it in my pocket anyways.
I use a straight pocket knife to remove the jacket. Just be careful and you won't cut any strands. I use a kitchen steak knife if I need to cut lengths......lol. It works pretty good though.
wire cutters, knu wire has thin covering i use wire cutters cut in about quarter inch from the front of the wire in to make like a sliver then peel it off around that way i dont lose any strands
Me too and then I have to paddle anywhere I want to go.
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
JoeK
JoeK
Ringtown, PA
Bettr n' Revrse
