How do YOU connect 2 pieces of wire to make a single run ?
TT2ENT
What do you guys use to connect 2 seperate pieces of 1/0 power wire so that they make one single lead/run ?
I was thinking using a fuse but that seems like a waste of $$ since they are so expensive and more than 1 would be redundant.
What hardware would do this while keeping cost and resistance in mind ?
That was him saying "use the search button"
I've searched this forum with all different wording and phrases and results are Dblocks and fuses...
blow torch alot of solder and a full roll of electrical tape
I don't have any acetylene atm and I'm currently on the unemployment check budget
Well if you're on an unemployment check, why are you worried about connecting two pieces of 1/0 and not about finding a job? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Because I want to use all of the $$ in my Unemployment account before I get a job. While I'm not working I'm living with and taking care of my 91 yr old grandmother while my Aunt and Unc run their store next door.
I am making just enough to get by with unemployment check, under the table.
Am I allowed to worry about connecting these 2 pieces of 1/0 now ?
perty much. how long is the total piece you be needin?
I have bout 15' of 1/0 already and about to buy another 12' to complete run + grounds and re-do "BIG3" in 1/0.
I'm trying to run from stock batt. UNDER the truck to the backseat area. 1/0 awg doesn't fit where I currently have my two runs of 4awg, under the plastic strip that runs along the botom of floor/door.
04 2500HD xt cab if that helps.
You don't. You buy a new run of wire.
o_O idk... worst case scenario = buying a fuse and holder (i think)
Back to reality and OP...
If taped/insulated, would 2 ring terminals on each wire connected with bolt and nuts would work ?
474
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
672
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
TT2ENT
TT2ENT
Hamsterdam, TX
Audiohazzard
    May 20, 2024
    May 20, 2024
