Immacomputer
Cloud disappear
....Where?
It was a rhetorical question. The impedance spikes will usually occur around system resonance where the system is the most efficient. It doesn't mean that it's the loudest here but that it is very efficient.
Take an infinite baffle setup into consideration (or the driver playing free-air). The sub will have a large impedance spike around the Fs of the driver. The driver will also have greatest excursion at this point. How can that be if it's getting so little power??? Well it's being driven into resonance based on the electrical and mechanical parameters of the system. Just like a mass on a spring with a driving force.
When you put the sub into a sealed enclosure, you change where the system resonance is because of the increased air-spring the driver is fighting. The impedance spike will also occur around that point of resonance and usually a little lower than the actual resonance.
Let's consider now a Helmholtz resonator with no sub attached. The system here will have an impedance spike around its resonance as well (the tuning of the enclosure). When you add the sub to the mix though, while the sub experiences the high impedance of the enclosure, it does not always share an impedance spike at this point (tuning). In most cases, the point of resonance in the sub/enclosure system is higher than tuning and in many cases, excursion will peak there.
If you want an enclosure with a minimal impedance spike, build a correctly tuned and stuffed transmission line. This will result in the lowest impedance spike. But don't expect it to be louder than your ported enclosure though. Maybe when you do it, you will realize that power isn't the end all to having decent output.
This part is an educated guess of where the spikes come from without really doing any research on it: I believe that you get the spikes due to the poles in the combined transfer function of the sub/enclosure/amplifier system. If you keep the original transfer functions at a low order, you reduce the number of poles. The more poles, the more spikes. There are ways to shift poles in the transfer function but I don't really understand that stuff well enough to apply it to sub enclosure systems.
