How do i remove the front speaker grill on 86-89 honda accord?
lamontjersey
nj
im looking at this grill on the front of this h onda accord, i put a screw driver under it and tried to pry it off, but im wondering if its screwed on from the inside, i dont want to break it. do i have to remove the door trim and install the speaker like that or is the grill supposed to just come off?
I know in most of the 89 honda's the grill will just pop off it needs to be pryed off carefully from the front or back I can't remember which.
If however your speaker grill looks much smaller than a 6.5 inch speaker, you will need to remove the door panel which is not hard especially if you have power windows. if you can post a pic of your car, I would be able to tell right away.
i opened the door and saw these two screws on the bottom, i took them off and pryed it off, and then i saw three screws holding the speaker on, i took them off and it was as simple as that. thanks for your help anyway. god, i hope these pioneers fit, they look kind of deep.
I have used a piece of hard clear plastic from a retail package to remove a stereo before. I am only half joking when I say that you should just...
I’d suggest if you’re using 409. Get some wax paper or Saran Wrap. Soak the fabric in 409. Then lay the wax paper/ Saran Wrap over wherever the...
30
5K
10
556
lamontjersey
lamontjersey
nj
mykeys
    May 18, 2024
    May 18, 2024
