How do I hook up speakers/tweeters without a crossover?
sjv13
StayStrange
I'm running a pair of the Focal IS 165 comps. These have integrated crossovers somehow, so there is no crossover box needed. I am running them off the Alpine KTP-445, so there was no need for me to figure out how to wire them to a "real amp" before. Now I have a 4 channel on the way, and need to figure out how this is going to work.
Here is what I have to connect: amp, woofers, tweeters.
There is no crossover involved, so I'm not really sure how I get it down to two wires (+/-) from four (woofer +/- and tweeter +/-).
Any information on how to do this would be great!
Just hook them up the same way they're running right now on the Alpine amp.
But that's the thing. I don't know what's going on with the Alpine amp because it just uses a wiring harness. Do you think I can just wire the positives of the woofers and tweeters together and the negatives of them together? Just by splicing?
No, I'm really not. I've never wired a "real" 4 channel amp before and there is no manual for the Focals, and I can't find any information online any where about how people have hooked them up to an amp before.
[quote name='>>SQL
There are no magical built in crossovers[/quote']
this... you need the crossovers. do a google image search and you will see what they look like. it has a input + &- (from amp) and a woofer output and a tweeter output. there is one of these for the left and one for the right speakers.
you are missing these
Well, if no crossover is needed, run the Front RCA from your HU to the amp. At the amp end put a 'Y' splitter on each RCA. Plug the left channel RCAs into channel 1 & 3 on the amp, and the right RCA channel into channel 2 & 4. From the output side of the amp, run channel 1 to the left tweeter, run channel 2 to the right tweeter, channel 3 to the left mid, and channel 4 to the right mid. That keeps your tweeters on one gain and your mids on another, so you can dial them in independently. Although, it might be helpful to know which 4 channel amp is on the way (the Polk in your sig?).
Someone please correct me if I'm off base here.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Yes. It's the one in my sig. That might work. But I'm gonna try to see if I can contact Focal about it and see what they'd recommend.
[quote=>>SQL
*SNIP*
I know what crossovers are... I'm just not sure how to hook up my speakers to a 4 channel because they somehow don't use one. That is a selling point of the "Integration" line of speakers from Focal.
ok buddy - you are right.
Your speakers have built in 6db crossovers on them.
What is it you want to do? Me personally I would run the tweeters from 2 channels of the 4 channel amp and the mid woofers on the other 2 channels.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
sjv13
StayStrange
sjv13
Lansing, MI
sjv13
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
