how do i connect my amp, quad 0 gauge inputs
my subs are dual 1s I might as well just do 1 ohm, but since I only have 1 battery under the hood im kinda holding off on that for a while. I changed out my cca on my big 3 and put the ofc 0 gauge, cold start voltage was 14.8.. 14.2 after nearly an hour of beating. with the stock alt and brutus amp. havnt changed the alt yet need more ofc wire, I am NOT going to throw cca on that amp lol
soundqubed 4500, how do I connect it. never had a amp this big. gna install my 370a alt, and I have a d3400 under the hood, gna wire at 2 ohms and see what she can do
Seriously? Hook the wires up..
What? Lol you put pos to pos and neg to neg? And why 2ohm? Not going to make much power, wire to .5ohm and have a volt meter and just set gain so u don't drop below 12v to keep the amp happy.
^this
Wow. You couldn't even wire to two ohms using all the coils on both subs. What are you talking about????
^this
i have 4 dual 1 18s. what are YOU talking about? cant wire to 2 ohms? your no help bro. stay off my thread. thanks
Your sig says two havoc 18's. You also said "might as well just do 1 ohm". How may subs are you using? You contradict yourself. Can't wire to both while using the same number of subs.
weather I connect 2 or all it wont matter because im just connecting it to see if the thing works, it hasnt been connected since I bought it almost a year ago
BassAndBeer
BassAndBeer
California
mylows10
