BassAndBeer
soundqubed 4500, how do I connect it. never had a amp this big. gna install my 370a alt, and I have a d3400 under the hood, gna wire at 2 ohms and see what she can do
Seriously? Hook the wires up..soundqubed 4500, how do I connect it. never had a amp this big. gna install my 370a alt, and I have a d3400 under the hood, gna wire at 2 ohms and see what she can do
^thisWhat? Lol you put pos to pos and neg to neg? And why 2ohm? Not going to make much power, wire to .5ohm and have a volt meter and just set gain so u don't drop below 12v to keep the amp happy.
Wow. You couldn't even wire to two ohms using all the coils on both subs. What are you talking about????my subs are dual 1s I might as well just do 1 ohm, but since I only have 1 battery under the hood im kinda holding off on that for a while. I changed out my cca on my big 3 and put the ofc 0 gauge, cold start voltage was 14.8.. 14.2 after nearly an hour of beating. with the stock alt and brutus amp. havnt changed the alt yet need more ofc wire, I am NOT going to throw cca on that amp lol
i have 4 dual 1 18s. what are YOU talking about? cant wire to 2 ohms? your no help bro. stay off my thread. thanksSeriously? Hook the wires up..
^this
where you located? Im near Monterey, im also looking for some good 0 gauge wireDrive to me on mon I'll help you
I'm in aromas. Out past Prundalewhere you located? Im near Monterey, im also looking for some good 0 gauge wire
Your sig says two havoc 18's. You also said "might as well just do 1 ohm". How may subs are you using? You contradict yourself. Can't wire to both while using the same number of subs.i have 4 dual 1 18s. what are YOU talking about? cant wire to 2 ohms? your no help bro. stay off my thread. thanks
weather I connect 2 or all it wont matter because im just connecting it to see if the thing works, it hasnt been connected since I bought it almost a year agoYour sig says two havoc 18's. You also said "might as well just do 1 ohm". How may subs are you using? You contradict yourself. Can't wire to both while using the same number of subs.
Sun or mon are my days off. Are you trying to got to the Turlock show on the 9th ?what about on a weekend? I have a busy work week
yeah I wanna try to make it out there, havnt been to a show in about a yearSun or mon are my days off. Are you trying to got to the Turlock show on the 9th ?
Looks to be bigger this yearyeah I wanna try to make it out there, havnt been to a show in about a year
btw if you happen to know anyone looking for 18s im selling 2 of my havocs they are the v3s 1500rms 900 for the pair, neither have seen over 600rms. im looking to down size for a trunk buildLooks to be bigger this year
