supercap bank size
MANTI5
I will be running around 1500w rms and want to add a bank to my system to help. What's the lowest I should go for in farads, I'm trying to keep the cost down but want to make sure I'm covered. I have a 2013 civic lx and will be upgrading the little battery to a group 34 agm also.
1 bank of super caps will be more than enough
you can get a used bank for around $150 if you shop around/wait for a deal
otherwise they run about $250 new
and the 2600f or 3000f banks will both do well. just make sure you have the correct voltage cells or they will be unhappy
Just for one bank. Expect to pay $175 to $250 easy. Only time you'll get them cheaper is if you buy quite a few at once even eBay they are $40+ each
I should have been more clear. I only planned on running one bank at 16v, I wanted to know how many farads I could get away with without it being overkill? There are a few kits between 58-80 farads for a little more than $100.
16v because I read if it's a newer car with an ECU, many of them go as high as 15.5 at times. Many newer cars have the bare minimum electrical to run on so adding a decent system is a no go on stock. There's no h/o alt option and the electrical system is such that you would need to mess with the computer even if one were possible. The bigger agm battery will help but keep_hope_alive said a cap bank is a necessity for our cars. I just don't think I'd need 500 farads (3000x6 in series) for my system.
MANTI5
MANTI5
Southern AZ
MANTI5
