How close can I get to 3400wrms for $400?
Thought.... I assume this guy is kind of a newbee the way it sounds... are you hooking the stuff up or anything? I was thinking you could just get him whatever amp you want and then just set the gains to keep the power down. Otherwise I think my selling him an over rated amp is a good idea!
don't the W7's have a weird voice coil? like a single 3ohm coils or something?
it's a two channel but it is "blingy" and will probably never put even 1Kw rms to each sub...
http://cgi.ebay.com/New-MA-Audio-HK602SX-3600-Watt-RMS-2-Channel-Car-Amp-NR_W0QQitemZ380215469270QQcmdZViewItemQQptZCar_Amplifiers?hash=item58869ba4d6
4 Pyramid 1000 watt amps 89.99 all day long on ebay. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes://content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Audio Savings | VISONIK 4000 WATT MONO HIGH CURRENT CAR AMPLIFIER AMP
Features:
4000W high current Amplifier
4000 WATTS RMS @ 2 OHMS
Signal to Noise Ratio: >96dB
THD: 0.5%
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Bass Boost Control at 45Hz: 0 - 18dB
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
Dimensions (H x W x L): 3.125" x 10.5" x 26"
RCA Line output
$399.95
Dont care what the ad says it isnt giving you that much - Sorry. If it were true watts you would be in an amp well over a couple grand, need a HO Alternater etc to get the current. need special wire and cable etc. It isnt just that easy was my point. Im running 2K true watts RMS and Im over 1100.00 just in the Battery, Alt which is custom and wires etc.
One easy way to know, Ask them what the amps Damping factor is. I'd bet they dont know or its maybe 25 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
One easy way to know, Ask them what the aps Damping factor is. I'd bet they dont know or its maybe 25 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
not true. im getting about 5k daily out of my amp and it was much less then a grand. the aqx3500 has been proven to do rated and its only 420. the audioque 3500d.1 does 4300rms and its only 750 brand new
true you will need an upgraded electrical to run it at full power but ive spent maybe $500 on my electrical and it sutains 5kwatt+ burps at about 13.8volts
LOL... ARE YOU SERIOUS? I hope not, I really just hope you are trolling...
LOL... it appears you actually are just ****ing retarded... http://www.caraudio.com/forum/car-audio-build-logs-*new*/468394-audiodaves-1996-blazer.html#post7016278
Serious about what? Yes I am serious and been doing Car audio for 20 years. My alternator alone was 550.00. Open up the amp case Id bet the case and board are not even close to matching in size. Even if they are, what STN%? What is the distortion at rated 10-25%? You put those amps your talkin about on a B&K and gauge it, it wont post but maybe half. As far as trolling, I havent done troll fishing for even longer.
Read specs on amps like this or compare apples to oranges.
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/A3000,A6000%20GTi%20Amp%20OM%20(Rev%204-1-04).pdf
MSRP 3500.00.
Serious about what? Yes I am seious and been doing Car audio for 20 years. My alternator alone was 550.00. Open up the amp case Id bet the case and board are not even close to matching in size. You put those amps your talkin about on a B&K and guage it, it wont post but maybe half. As far as trolling, I havent done troll fishing for even longer.
you got ripped off. my 300amp alternater was under $300.
were you talking about the amps i mentioned. I hope not. the audioque has been proven to do rated. that audiopipe aqx3500 has been proven to do atleast rated. and my amp i clamped at 5700ish @ .7ohms
DS Autosports
I LIKE SOUND!!!
DS Autosports
BFN, NC
abrhino
