How can I run 3 channel Alpine amp?
  • 5
Kaczman
Ohio
Hey guys, I have an alpine MRP-F240 amp that can be ran at 2/3/4 channels. The amp specs are:
40 watts RMS x 4 at 4 ohms
50 watts RMS x 4 at 2 ohms
100 watts RMS x 2 bridged output at 4 ohms
At 4 ohms 0.08% THD
At 2 0.3 THD
My friends got 2 5.25s that can take 40w Rms and 2 6x9s that can take 50w rms.
The amp says it is 3 channel capiable. Can I run the 5.25s at 4 ohms off channel 1 and 2 and bridge channel 3 and 4 together to give the 6x9s a combined power of 100w rms (50 per channel) at 2 ohms? Thanks!
i have that amp and it wouldnt like 2 ohms while bridged
just hook the 6 x 9's to ch 3/4 seperatelyso each channel is powering 1 speaker and call it good.
~Magick_Man~
The audible difference for the 6x9's when going from 40 to 50 watts is almost nil.
Just hook them up normally and all will be well.
PS- Alpine amps are slightly underratted so that 40 watt rating is probably closer to 50 anyway.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
Kaczman
Kaczman
Ohio
Decipha
    Apr 27, 2024
audiobaun
    Apr 27, 2024
