I have 2 DVC 4ohm subs that I want to wire to my 600x1@2ohm. Not stable at 1ohm
I want each sub to get about 300 watts at 2ohms.
The amp has 2 sets of speaker terminals and they are wired Parallel internally.
Now checking another forums sticky. I can wire each 4ohm DVC sub parallel into 2ohms. If I take each sub and wire them seperately to each set of speaker terminals are they now a 1ohm load on the amp? or does each terminal set see 2ohms???
Is there any possible way of giving the 2 subs 300 watts each at 2 ohms?
or am I stuck with either 1 or 4 ohm load on the amp?
