How big is yours?
Atomic
23
MS
Does the size of the box really have to be X amount of cubic feet? I want to put a pair of 10's in my wifes car. It's a spectra hatchback. There are two nubs sticking out of the wheel wells about 9.5 inches high. I can go 16 inches high. The base would come out about 10 inches but the top would be more like 3 inches. The nubs take out 3 inches of width also. Does this sound like it would be good enough air space for a grocery gitter? Would a pair of 12's be too much to ask? Stuff it with pillow fiber? Using the whole 37 inches in width it should make it just over 1 cubic foot. With it 34 inches it shows just under a cubic foot not including the thickness of the mdf or the basket. Would I be better off using fiberglass to maximize the space I have to work with? Do I just need to shut up and keep doing more research and use more math? I don't have any of the speakers or anything yet. This is a project for several months away. This is also going to be my first ever install for anything. I've never even installed a HU. I used to hang around with a guy who built systems for a living so I understand some things as I've held wood while it was getting screwed into place.
Another question you may can answer for me. Will my stock speakers be ok for a few months if I go ahead and get a head unit?
System will be:
HU - At least 1 rca in and 2 rca out. MP3 / cd / text
Amp - Sub only Doesn't have to be much but I'd like a volume control
2 10" subs probably kickers
2 6.5's for doors probably kickers
2 I don't' know what those are like a 4 by 5 or 5 by 7 I might just replace them with a 4 and tweet
2 tweets in the doors or a pillars
Should I use a cap? Should I run my other speakers off an amp or just use the HU?
Thanks for the patience and sorry for the incoherent rambling.
teh title.... i was like wtf another useless thread. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
since space is limited go sealed. infinity perfect 10.1 only require .60 ft3 for each sub this includes sub displacement.
basicaly shop for a sub that performs well in a small sealed enclosure.
or you might be able to have 1 12 ported without taking up to much room.
Atomic
Atomic
MS
btmorris972
BP1Fanatic
BP1Fanatic
