How are you using 0 Gauge?
It depends on the size of the amp, bigger amps bigger wires. If yours is four guage max then just use four guage.
Or you can do what Jim mentioned.
buy some better amps
seriously? you can surely provide him with better advice than this. If you don't wanna help the guy why even bother posting? I'm sure you are one of those that knew all there is to know about audio when you started right?
OP, like suggested above purchase a distribution block with 0 gauge inputs and 4 gauge outputs. Problem solved. Good luck
I dont see wasting your money on 0 gauge if your amp requires 4 gauge
If you ever upgrade then id be looking into 0 gauge.
Since I sold my 3500D and pulled my HDC3s out Im running a temp setup with a Kicker 400.1 amp with my 0 gauge. It actually fit fine in the terminals //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
If the amp won't accept anything bigger then 4ga. there is no need for a bigger wire. A high quality 4ga wire will provide the amp with all the power it needs up to about 20ft. You could upgrade your big 3 with 0 gauge to see a gain there or if you wanted to run the 0 ga in case you ever upgraded amps reducers or distro block as said before..
alex50
alex50
Tulsa, OK
tylork92
