Hooking up a relay and need help. (I must be slow)
Nico Koutouzis
Anyays, I bought an automotive relay 30A from radioshack and an N0001 diode. If I use my accessory plug for the remote line do I still need the diode? If I use the remote line from my HU where do I solder the diode. Its a 4 pin relay so it would help if someone told me what goes to what. (ground, +12v, Remote Line, and the wire to power my accessories). PLEASE HELPP
Relays
Quenching Diodes:Anytime that a relay coil is driven by a circuit that is not specifically designed to drive a relay, you should use a quenching/suppression diode connected in parallel with the relay coil. The diagram below will show the connection of the diode. Initially, you may think the diode serves no purpose because the voltage applied to the relay cannot pass through the diode. This is true when the relay is energized. The diode comes into play when the power source is removed from the relay coil. When power is applied to the relay coil, a magnetic field is created and energy is stored in the coil. When power is removed, the magnetic field collapses causing a reverse voltage to be generated (it's called inductive kickback or back EMF). The back EMF can easily reach 200 volts. The diode will absorb the reverse voltage spike. This voltage, if not absorbed by the diode, will cause premature failure of switch contacts and may cause the failure of power switching transistors. You can use virtually any type of rectifier or switching diode (i.e. 1N4001, 1N4002, 1N400x... or Radio Shack part #s 276-1101, 276-1102, 276-1103, 276-1104).
you can see a wiring diagram in the link above.
i was starting to type a similar answer, then remembered bcae1 has it already.
Nico Koutouzis
Nico Koutouzis
Hartford, CT
maylar
