Honda CRV Amp Installation
  • 2
jmmonzon
I am planning to install my Alpine 3542 amplifier in my Honda 99 CRV but I dont know where I can exactly run the power cable into the car. I checked the hood this morning for places I can insert a power cable but could not find any. Any suggestions will surely be appreciated. Pictures are most definitely going to help.
Also, if I install the amplifier under the drivers seat, is there a specific place I should be careful in screwing the amplifier?
The power will easily run through the round gromet just under the battery on the passenger side of the firewall. It is a few inches towards the center of the car from the battery and about 6 inches below it.
Because of the power wire going through the passenger side I would recommend putting the amp either in the back or under the passenger seat. There is nothing under the passsanger seat to worry about drilling into, but there may not be enough clearance under the seat to allow it to slide all the way forward once the amp is installed.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
681
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
I loved my JVC head unit. Got it for a steal and never had an issue. Pioneer on the other hand, had 2 with constant issues. I installed that Sony...
16
247
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
475
jmmonzon
jmmonzon
San Francisco CA
Pete
slater
    May 2, 2024
slater
    May 2, 2024
