i can make it happenI wonder if Tantric will put a pink carbon dustcap on the shd I'm gonna run. Hmmm...
you don't think i can get away with one 250 amp alt?I would run a pair of 200's or 250's or your stock alt with like a 300 amp.
I'm sure you can "get away with it", but if you can generate what's being drawn without dipping into your batteries, you're friggin golden.you don't think i can get away with one 250 amp alt?
cool thanks ma you really helped me out!I'm sure you can "get away with it", but if you can generate what's being drawn without dipping into your batteries, you're friggin golden.
That being said, the brackets for multi alt setups can be pricy. I'd just get the baddest mf'ing alt you can get under your hood.
You can, but it's very simple man. You're not producing as much power as you are using. So your voltage will drop.you don't think i can get away with one 250 amp alt?
what would happen if I ran the amp on 1 ohm until i got my alt, which is when my next paycheck comes on the 10th. could it damage my amp? this is just my dd truck so its not like I'll be competing.No problem and good luck. Show us your new alt when you get it in.
alright i just wanna have a little bass until i can afford the alt. can I just get one through you?Keep the volume down and you maybe ok
Yesalright i just wanna have a little bass until i can afford the alt. can I just get one through you?
