vehementSPL
There was something I was playing around with in WINISD and it shows me if you take the exact same port area and divide it into two ports it raises the tuning. So same total port area . so take 400 inches and put it in one port vs 2 200 inch ports. WinISD shows the tuning to raise considerably. I am like cool. Put a port divider and raise tuning. Problem is this 4th order peaks NO where near as high as it shows. Then when I look at the graph with the full amount of port 400inches. it follows that graph pretty close. This box has 400 inches of port and the port is 3.5 inches deep. Without a divider in it is tuned to around 47ish . Any ideas on how to get the tuning up. Or is there some sort of odd rule as where there has to be a certain amount of distance between the two ports of it to react as two separates and raise the tuning
