High pitch sound in my music.......Y?
fire919
ok so i've got 2 6x9's hooked up to a 2 channel amp. when the car is off its plays good....but the minute i start up the car i get a high pitch noise
that completely drowns on the music...and th only way to hear it iz to crank the volume wayyyyyyyy up........y is this happening.
will try that could be the problem for real nvr thought about that , thx bro........96' Mustang on 19's i love those cars ......."(i keep em clean though).....lol" next friday right
Sounds like alternator noise. Does the pitch change with the RPM speed of the engine (i.e. get higher pitched as the engine revs increase?) If so, it's "alternator noise." Make sure grounds are good (sanded paint = ground wire hits bare metal, good solid ground, ground wire is thicker than power wire) and check that for your alternator too, to make sure it is properly grounded.
Decibels are a measurement how loud something is...it's not the frequency of hearing...
19
Unfortunately barly someone does these things in my country, and the ones that do, makes it so expensive to test it or even fix it that testing it...
With the new info that factory amp is still connected, Coolhand20th's original assesment may be right. Radio may be causing the noise. I would...
14
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
84
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
650
fire919
fire919
the bronx,NY
SlipTap
    May 12, 2024
Brendon Jenness
    May 11, 2024
