High ohm load capable amplifier?
Belialz
I'm looking to run an Eminence 21" Pro Audio subwoofer In a paraflex enclosure. The problem that I'm having is trying to find the right power to push this 6 ohm subwoofer. It's not a DVC, it doesn't come in any other ohm load except for 6. this is not going to be a competition SPL system. this is going to be very musical but extremely loud. We all know all car audio companies list their amps in low ohm loads. I need three to four thousand watts in 6 ohm.
Man that sub is 97db, you could probably get away with a 2000 @ 4 ohm amp and never turn it all the way. That'd net you around 1500w @ 6... and with that kind of efficiency... probably make your ears bleed.
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
483
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
458
Belialz
Belialz
Atlanta
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
