high end output to run sub help
you mean off the speaker outputs? you can get a loc line output converter this will change the speaker wire to rcas then just use the amps lowpass filter and you should be fine if your amp has speaker level inputs use those.
thanks bro If you need a ****** plumber's advice ahm all ears there are some punks on this site you aint one a them
dont come in here acting like you fucking own the place. Try being a bit respectful...you dont need to post 8 threads about the same thing. And by the way, no matter what you do...this LoC and sony crap is going to sound like shit/not work no matter what you do
mstauffer
mstauffer
Globe AZ
plugitin
michigan born
    May 14, 2026
michigan born
    May 14, 2026
