hifonics zrx3000.1 d, barely used $200 plus ship
ktraughb
hifonics zrx 3000.1d
3k at 1 ohm, 1500 at 2 ohm. good, solid amp. im 99% sure this is the same board as the brz2400, which is a decent amp. ive not clamped any 1 ohm tests, however, i did get about 1700 at 2 ohms, so definitely not bad. i literally used this for only a few days to do some testing before meca world finals.
200 plus ship.
varies, just pm me for a quote
dont have any with username at the time. im out of town, but i can have my gf get a photo for that if need be.
btw when testing with this amp, it had absolutely no issues playing at .35 nominal. as i said, i did clamp it rising to 2 ohms, where it did about 1700 ish and did a 147.6 on two shocker sig 15s in a street box. i got much louder with a solid 3k, but i couldnt keep this particular box rise down to test lower ohm load.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Based on everything else you've said so far, I'm wondering exactly how you have the LoC connected "through your subwoofers". Is it possible that...
23
ktraughb
ktraughb
Louisville, ky
ktraughb
    May 20, 2024
    May 20, 2024
