Hifonics XXV-COLOSSUS can I run this for highs/mids?
mmouse57
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18561
this amp above
as in bypass the internal crossovers and run full range via the ouput on my radio through say a kicker 3 way crossover set at 100hz up
so bascialy use the amp without the remote and crap just bascial singal
I ask i used ot run a gen 5 zeus 300x2 amp on my highs and they where out of this world
this amp looks to be the same just seems ot have only low level crossovers buid in and i cant find a manual to see if i can run this amp full range //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks guys
this was not a "why would you" question but a "is it possible" question
you would think all amps would have the ability to run a full range input but if you are sure 250hz is the high then thats no good //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
thanks guys
i am absolutley positive 250 is the limit it is a class d amp and class d is sub bass only due to inefficiency and other key reasons. t class digital amps are here now though for mids and highs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks guys
I think the reason why you "can't" is the same reason why the manufacturer
thought you "shouldn't". Some class d amps just aren't meant for full range
duties due to the frequencies that they do their switching at.
Besides that, I don't personally know of a component set in the world that can handle that much power.
But if you're serious , Zapco makes a couple of full range, high power amps that
may suit your needs.
http://www.zapco.com/prod/comp_prods/c2k90Frame.htm
http://www.zapco.com/prod/comp_prods/c2k4kwFrame.htm
http://www.zapco.com/prod/ref_prods/10004Frame.htm
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
mmouse57
mmouse57
saint cloud
stereojnky
    May 12, 2024
Brendon Jenness
    May 11, 2024
