SOLD Hifonics XX-Colossus-II
Cisko
* Dual Mono Class "D" amp
* Ultra class D design
* 3200 Watt Class-D Monoblock Amplifier
* 1 x 3200-Watts RMS @ 2-Ohm
* 2 x 1600-Watts RMS @ 1-Ohm
* Illuminated Hifonics badge logo
* Removable 20th anniversary endcaps (NO LONGER WITH THE AMP)
* Ultra-hi speed MOSFET output devices
* 2 Gauge power connectors
* Top mount controls
* 180° Phase shift left and right
* Subsonic filter: 10 - 50 Hz +/- 24 dB
* Low pass filter: 35 - 250 hz +/- 24 dB
* Variable Q control
* Variable Bass EQ: 0 - 18 dB @ 30 - 60 Hz
* Master / Slave operation
* No rear cover/ fan cover died out
* Regulated PWM power supply
* Generation XX EXVP (Exponential Vari-Power Supply)
* Diagnostics Indicators - Thermal, Overload, Power or Protect
* Gold plated RCA indicators
* RCA Outputs
* XLR mini DIN sockets for balanced line input
* Variable input level: 200mV - 9V
* Dimensions: 28" Lx 11.2" Wx 2.6" H
* THD 0.1%
* Preamp Outputs
* Bass Boost 0 - 18 dB
* Signal-to-Noise Ratio 98 dB
The rear cover is missing because i had 2 fans... the cable where changed to 8 gauges this amp was hitting hard here's a video of the car that had it 2RCF P300
PM IF ANYTHING I'LL GIVE YOU MORE INFO
Askin Price $575 or O.B.O no low balla THANKS IN ADVANCE
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Cisko
Cisko
Washington Heights, NY
baggedsunfire
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
