Sold Hifonics XX-Colossus-II
Cisko
* Dual Mono Class "D" amp
* Ultra class D design
* 3200 Watt Class-D Monoblock Amplifier
* 1 x 3200-Watts RMS @ 2-Ohm
* 2 x 1600-Watts RMS @ 1-Ohm
* Illuminated Hifonics badge logo
* Removable 20th anniversary endcaps (NO LONGER WITH THE AMP)
* Ultra-hi speed MOSFET output devices
* 2 Gauge power connectors
* Top mount controls
* 180° Phase shift left and right
* Subsonic filter: 10 - 50 Hz +/- 24 dB
* Low pass filter: 35 - 250 hz +/- 24 dB
* Variable Q control
* Variable Bass EQ: 0 - 18 dB @ 30 - 60 Hz
* Master / Slave operation
* No rear cover/ fan cover died out
* Regulated PWM power supply
* Generation XX EXVP (Exponential Vari-Power Supply)
* Diagnostics Indicators - Thermal, Overload, Power or Protect
* Gold plated RCA indicators
* RCA Outputs
* XLR mini DIN sockets for balanced line input
* Variable input level: 200mV - 9V
* Dimensions: 28" Lx 11.2" Wx 2.6" H
* THD 0.1%
* Preamp Outputs
* Bass Boost 0 - 18 dB
* Signal-to-Noise Ratio 98 dB
The rear cover is missing because i had 2 fans... the cable where changed to 8 gauges this amp was hitting hard here's a video of the car that had it 2RCF P300
PM IF ANYTHING I'LL GIVE YOU MORE INFO
Askin Price $575 or O.B.O no low balla THANKS IN ADVANCE
Cisko
Cisko
Washington Heights, NY
baggedsunfire
