Hifonics BRX1600.1D
fire919
if i get this amp and run it @ 2ohms, do i have to do any electrical upgrade, to achieve rated power. everything is currently stock (05 Honda accord). thanks in advance.
Brutus Series Monoblock Class NextGen Super-D Car Amplifier
RMS Power Rating (@ 14.4V):
4 ohms: 600 watts x 1 chan.
2 ohms: 1200 watts x 1 chan.
1 ohm: 1600 watts x 1 chan.
you've probably got a 110 amp alt so you should b ok there. zero guage wire for big 3, power and ground and a decent batt and you should be good.
I have one in my 2001 Lincoln Continental with a XS D680 and stock battery under the hood, stock alternator, and upgraded grounds. When my car is running and sub is going full tilt my voltage doesn't get below 13.3V, car only idles at 13.8V. You should be good if you do the right electrical upgrades. I love this amp btw, you won't be disappointed //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have one currently pushing an Fi BL 15 in a saturn vue. all stock except big 3 with 0 gauge. and i play it at 1 ohm and it does fine. you should be good with the big 3 upgrade as long as your alt is 110.
fire919
fire919
the bronx,NY
Giovanni15
BP1Fanatic
BP1Fanatic
