hifonics brx 2400.1 mint
as of right now its temporatily on hold by me. fcukin ups driver jacked my stetsom amp that was shipped out for repair so im waiting on getting my insurance refund from them and am going to buy a saz 5000 and once i get that it will be back up for sale. sorry guys
so you got a jacked up stetsom, you sent it out for repair and the ups guy then jacked it from you? sounds like you need a new shipping service o_O
**** i know man. what a bad series of events but im tryna look at it on the bright side im going to have a sundown 5000 instead of a stetsom and i would rather have the sundown any day. but yea its been a ****** month n a half with me and amps lol
when you send it you have to give a description of the item so when the driver seen it was a amp he took it home with him , sure enough his dumb *** got a crapped out amp and i bet money hes on one of these forums tryna sell it
It's a high end marine quality four channel amp 125 x 4 @ 4 ohms, here are the specs: Xi Multichannel Amplifier Technical Specifications
Size and Weight
Xi800.4
Length
16in. (457mm)
Width
10in. (254mm)
Height
2.5in. (64mm)
Weight
Power
Xi800.4
Into 4 ohm Stereo
125W x 4
Into 2 ohm Stereo
200W x 4
Into 4 ohm Bridged
400W x 2
Onboard Fuse Size
30A x 2
Power / Ground Wire Size
4 Gauge
Specifications
Frequency Response ± 1dB from 20Hz - 20kHz
Signal to Noise Ratio >110dB
HP and LP Xovers
18dB per octave
LP Xover Range 40Hz - 400Hz
HP Xover Range 20Hz - 400Hz
Input Sensitivity 200mV - 8V
Lowest Recommended Load 4 ohm Bridged or 2 ohm Stereo
Typica Efficiency 50%
Specifications subject to change.
The Xi Amplifier System.
What Accessories Come With it?
1 Exile Xi Power Amplifier
Mounting Accessories
1 Owner’s manual
vibe
vibe
Prescott, AZ
vibe
