Hifonics Amps
Was all the rage 10 years ago. You couldn't get more power for less money. Remember the XX Collosus? That was so bad *** back then. I wouldn't buy them now with quality budget brands like Soundqubed around but if you can get it cheap then it's not a bad amp. Expect a 2500 to put out about 1600 as an example. So don't pay more than 1600 chinese watts money.
Lmao brz and brx lines do every bit of rated theres nothing wrong with running hifonics theyre just power hungry amps , where the hell do you guys come up with some of this **** lol
actual clamps on on oscilloscope on overkill electrical. Without an oscope, even boss amps make rated dirty power.
Brutus elite, their best amp, failed certified runs on the dyno, just imagine what their normal brutus lines do.
brutus elite 1700 watt amp only making 1199 watts clean.
On the amm-1, best the brz 2400 got on a dynamic rms run was a 2055 and dynamic rms runs are utterly useless considering we listen to long dragged out bass lines more than pulsing bass punches like normal people.
And dynamic can be dirty.
this. I'd take a hifonics over many of the internet boner brands that are hyped on the forums today.
now THAT is the dumbest thing of the day
---------- Post added at 12:29 PM ---------- Previous post was at 12:28 PM ----------
Naw mayne dat **** loud af n clean like bae
In a sense your right , now brutus elite **** **** and will not make the power the older brz and brx where about as good as they got a few years back and id still run them to this day all that dirty power clean power is bs if its unclipped or very soft clipped run it its fine , and noone runs an amp dyno in their cars so i dont use numbers from that its nothing more than another marketing technique to get tony rich and make ********* believe a 2k can do 7k you can use it to ball park an amp but noones running 14-20 g31s in their car to produce 2k
Lolwut
When da bass hits and the ohm of the amp goes active and the when power cap times the number of battery's while -5db tone track will double bass boost power tone level input. Know what I'm saying?
Lmao dirty power ........
FSD 2600 for 332$
Brutus elite 2500.1 for 375$
for cheaper than hifonics, you can get an amp that easily does 100 watts more than rated certified dyno numbers and 3k with uncertified and 3.6k with dynamic. You still gonna defend hifonics crap after that? Price to performance, ratio is SH*T with hifonics unless you get for dirt cheap used but you can get proper korean board amps used as well.
compared to that brutus elite that barely passed by the inch of its skin with dynamic numbers and flubbed the other two numbers on steve meade's test which one do you really think is good for the money?
https://www.youtube.com/watch?v=_Qr8uhLD5tAhttp://www.youtube.com/watch?v=_Qr8uhLD5tA
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
165
AcuraTL
AcuraTL
Burnaby
bgowdy
    May 18, 2024
    May 16, 2024
