Hifonics 1606d Actual Power rating
  • 5
krisfnbz
Frederick MD
I used the search button //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I know this baby does 1100 @ 2 ohms(so they say) at 14.4v
and Im currently running it for 1600 watts @ 1 ohm at 14.4.
Well with my car turned on and in idle, Im getting the reading of 13.5(give or take) and when I rev it, im getting 14+.
I bought the amp to power my L7, and I knew that it was slightly under-rated, but does anybody know by exactly how much? 2 questions.
1. Lets say im running at 14.4v(or higher), whats the most power I could get out of it?(Im guessing like 1400)
2. Lets say im running at 12v, whats the most I could get out of it?(Im assuming like 1200?)
Are you talking about actual power into a speaker or into a static load? There is a big difference between the two. You'd be better off setting the gain with an o-scope rather than trying to figure out how much power it's making. The newer ones are supposed to make rated power anyway from what I've heard.
My question becomes why? Does a couple of watts that you can distinguish by ear matter?
Its not really a BIG deal to know, but I figured I would ask around on the forum what kind of wattage this amp ACCTUALLY puts out because ive heard from some people 1400 and from others 1500. Dont get me wrong is does push the L7 enough so that im 100% satisfied, Id just like to know thats all. My grounds are good for my spare batteries, so my voltage is fine... I just know that these amps are under-rated(well everyone says so)
I would say they do around rated. I have my gains set to 40v around 1600wrms and the at full tilt i don't smell any coils and the amp doesn't get real hot so, i don't believe it's clipping. I would say between 1400-1600 wrms. Its a solid amp
You mean OVER rated? Last I heard the most recent ones are pretty spot on.
yes I meant over-rated sorry about that...
okay cool thanks for the input. I appreciate it.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
krisfnbz
krisfnbz
Frederick MD
krisfnbz
