hifonics 1205d (mono block?)
Amalan
im trying to put a system together and i bought a hifonics 1205d and it says mono block on the amp but there are 2 speaker outputs as if it were 2 channel? my friend is borrowing my camera but it says " Speaker Output" then 4 screw down terminals in this order " + + - -" im not sure what do here. i have 2 svc 4ohm subs that i want to wire into 2 ohm on this amp. what should i do?
helpppp
heres a pic of what im talking about. there speaker output is on the right
The Amp is 1 ohm stable. If you had 4 of those subs you could wire 4 of them to a 1 ohm load. To answer the question wire it on the amp like this wire it to the first positive on the amp and the last negative.
why would you suggest buying 2 more subs? lol stupid idea.
man im confused how does each sub see a 2ohm load if its not wired parallel? does the amp internally wire parallel? so each sub to each of those outputs would give him a 2 ohm load like in that picture?
Amalan
Amalan
Cincinnati
blong131
