Amp for Fi X-Series(2)
JB16
What amp would you recommend for these> They run at a 300rms, so I was thinking something that can supply 400ish to 2 duel 4 subs. Would like to keep in
Stats of Sub:
10 DUAL 4
Fs: 25.9 Hz
3.9 Ohms/coil
Qms: 3.90
Qes: .35
Qts: .32
110g
: 0.34mm/N
Sd: 310cm^2
Vas: 45.7 l
Spl: 85.4dB 1W/1m
Bl: 20 N/A
Xmax: 16mm
Rms: 300W
Sealed box: .5-.8cuft
Ported box: .9-1.5cuft
Sub OD: 11.0
Cut ID: 9.25
Mounting depth: 5.25
Displacement: .07cuft
Any suggestions would be awesome.
thanks
i think a sundown sax 100.2 bridged to 4 ohms would be nice match for an amp that cost around 240 shipped new and puts out 450ish in 4 ohm load. for slightly more power id suggest sundown 1000D. does 1000 @ 1 ohm, 2000 @ 2 ohm strapped with another 1000D and 400 / 600 watts in 4 ohm and 2 ohm per.
Mike-
JB16
JB16
New York
Decado2
vegang
vegang
