Hi First Time poster. Question on Amps
Hello, I need some help figuring out what amp(s) I need to support my current setup.
This is my Current Setup. TOTAL of 3 Subs.
SONY SUBS X 2
Manufacturer Part Number XSGTX121LS
Manufacturer Sony Corporation
Product Model XS-GTX120LS
Product Name Xplod XS-GTX120LS Woofer
Impedance 4 Ohm
Driver Type 12" Polypropylene Woofer
Minimum Frequency Response 42 Hz
Maximum Frequency Response 1 kHz
RMS Output Power 300 W
PMPO Output Power 1000 W
PIONEER SUB X 1
RMS Output Power: 300 W
PMPO Output Power: 1300 W
Driver Type: 12" Polypropylene Woofer
Minimum Frequency Response: 20 Hz
Maximum Frequency Response: 220 Hz
Impedance: 4 Ohm
Sensitivity: 95 dB
Are they dvc or svc? Just figure that out so you know how you want to wire them and then pretty much anything that can handle the load that you create will push those without a problem. Its not really a matter of power for these subs, it's a matter of impedance or resistance and making sure the amp you pick is stable for the load you create by wiring them in series or parrellel. Hope that helps. Going forward you might want to figure out what you have for power and then choose subs based on that.
MrFordRanger
MrFordRanger
NorthEast Ohio
rlmich
michigan born
    May 14, 2026
michigan born
    May 14, 2026
