Hi, Another enclosure question :)
  • 2
LuRp
NY
hey guys, i have 2 Rockford 10" HE's and i found this box for sale on ebay for $36. I think this sounds like a great price for a dual 10" enclosure. So my question is, is this a good box? if it is, it is good for my subs? and does that sound like a good price to you. Thanks LuRp
It's made form 5/8" MDF
This box has external dimensions of 13.5"H x 13.5"D x 30.32"W , and an internal volume of 1.05 cu. ft. per side, which is perfect for two 10-inch woofers optimized for larger enclosures
Dimensions
13.5"H x 13.5"D x 30.32"W, and an internal volume of 1.05 cu. ft. per side
Enclosure Type: sealed
Subwoofer Opening Size: 10"
Number of Subwoofers: 2
Speaker Terminal Type: spring-loaded
Sealed Chamber Volume: 1.05 cu. ft.
DEADEN THE INSIDE WITH DYNAMAT OR CASCADE 5/8" IS A LITTLE THIN MAYBE RESIN THE INSIDE AND DYNAMAT IT AT THAT PRICE ITS GOOD BUT SHIPPIN GONNA KILL U
$20 shipping... sounds pretty reasonable to me.
Ok thanks. Thats what i was worried about...
in general shipping for a box costs more.........but if its only 20 and it fits your car why not get it? but i will also say this...at local shops here they sell boxes that are about the same as that but are not a name brand (r/t, q-logic being name brands) for 50........if you find it local might cost less.
ok thanks alot for the input. Is there really that much of a diff between 5/8" and 3/4" in terms of sound? b/c what im looking for is a hard hitting very clear and crisp bass.. Thanks again
LuRp
welp this is how i can best put it... the "deader" the box the better and if for 30 bucks you can improve your system.....id do it my firebird had 2 1" layers in each wall with roadkill (stinger dynamat lol ) sandwiched in between... box was dead as hell
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
LuRp
LuRp
NY
audiolife
Brendon Jenness
    May 8, 2024
    May 8, 2024
