Hey guys
I think you could get by with 1.5cubes sealed on that 18"... just make sure to turn all the gains and bass boosts up on the amp and head unit... you will get some heads turning and get that girl very impressed man...
2 Cubic ft at 40hz would sound great on that 18, really smash the lows. As another member said make sure you turn all the settings on the amp all the way up, especially the subsonic filter. With that amp you wont need any more than 8 gauge power wire and a capacitor.
OSB is the best material ive found. That or what they call "Flakeboard" When it gets wet it swells up and seals better. After you build it leave it in the rain for a few days and all the cracks will seal up.
Formaldehyde mixed with toulene and xylene is a good combo, but the box will be kind of sticky for a while. I mixed some one time and used it on some MDF. I call it "super swole"
pure salt water is the best i've found to soak the osb in.. also you could try this stuff called particle board. just use 1/4 and elmers school white glue. will hold like a beast man..
fuckin LAWLZZZ //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Ok for the best results follow the advice given on the box. Also get a 59 farad cap from boss. Thats their best product. Also run 20 gauge speaker wire to that sub and 8 gauge to the amp. Also run a 150 amp fuse on that power wire.
---------- Post added at 01:58 PM ---------- Previous post was at 01:58 PM ----------
I meant 50 not 59
T.I.K.
F*ck it, we'll do it live
T.I.K.
Michigan
kramer_212
