Help!!!!!
Justinjay
I have a kicker 800.1 amp two re audio pro 600w rms/12"/dvc with a kenwood ktv 514 receiver.
I need help giving them optimum performance. I screwed with the settings on my amp so much I'm lost. Please break it down as much as you can, as I am a beginner. The music I listen to is rap, so I'm looking for hard hits and loud low bass. Once again, I need help with the settings, any help would be greatly appreciated!!!!!!! The subs are in a sealed box.
Subsonic 10 hz - 80
Low pass x over 40 hz - 160
Center freq 20 hz - 80
Bandwith 1-5
Boost o db - 18
Once again I'm a beginner please take it easy on me, an please help! Thanks...
Not originally from here. Originally from Milwaukee, up by you pretty much.
What model Kicker amp is it? 1 ohm or 2 ohm stable? And what voice coil config. are the subs? You might have them wired incorrectly as well. And what are the dimensions on the sealed box?
Its a class D, I see a 2 and a 4 ohm on the box the amp came in, 2 ohm mono 800, and 4 ohm 400 mono, car tunes installed them, don't know the dementions of my box. Is there just an in the ballpark range of what I should do? I'll slowly tweak it from there... ?" Sorry if I'm annoying you Really New to this!
Justinjay
Justinjay
Detroit mi
Justinjay
NorthFramingham
    Jun 30, 2026
