help
connersdad19
i have one run of 4 gauge stinger power right now...im going to be adding a battery to the trunk....like a hc800...would i be safe if i just ran 2 runs of 4 gauge? the amp i have is a cadence txa1000d.....i dont wanna spend a lot of money on 0 gauge and i already have one run that is ran and it would make it easier..to just add one more run..of 4 gauge instead of buy 0 gauge and being stuck with the 4 gauge...so my question is can i get away with 2 runs of 4 gauge power to the back battery?...just wanted to know what everyone thought.
Yes that will be fine, but you will need to fuse each wire, within 18 inches of the battery at each end (4 fuses in total), plus any fuses in your distro block, if you're using one.
connersdad19
connersdad19
Logan, Ohio (43138)
connersdad19
vegang
vegang
