Help with wiring 2ohm or 4ohm DVC subwoofers
USAFradartech
I currently have a Kenwood KAC-9105D amplifier and am in the process of getting 2 Rockford Fosgate T112D4 or T112D2 subwoofers. I will be buying one first and installing it, then a 2nd about a month later. How would i go about wiring these subs to get the most power out of my amplifier? What would be the easiest option? to buy 2 ohm or 4ohm? The amp is 1ohm stable.
New to the forum. Thanks!
I already have the amp, i currently have a box for 2 12"s, just getting these subs to upgrade from my old ones, they were ****** and i fried the voice coils. Its just a funds issue, thats why im buying them one at a time.
I suppose i could just order them at different times an then put them in at the same time. Just a funds issue is all! gotta pay the bills //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Your box. Is it a prefab? You will notice a nite and day difference if you save for a custom. The d2s are not gonna wire down to 1ohm load once you have both. That's another reason why you should save a bit more and get them both at once. Also look into other brands. 2 LIs will blow those RFs away.
This would be better than installing one then the other later. Get d4s in that case. :)
Ya its a prefab. I would prefer a custom, but im not exactly at the best location to get a custom box built. Im at a pretty remote base in germany, so a prefab was easier in my case. Alright i will look into the d4's and wiring diagrams on those. LI's? sorry not quite sure what those are.
Incriminator audio lethal injections. If you decide you want those instead message me and i'll send you the right way. Btw what branch? I was air force...
USAFradartech
USAFradartech
Goldsboro, NC
USAFradartech
