help with w6's
spike_e
ballin on a budget
3 DVC drivers with Voice Coils in Parallel / Parallel
Connecting the two voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel will result in the following impedances:
Dual-6 Ohm Subwoofers: 1 Ohm
Dual-4 Ohm Subwoofers: 0.67 Ohm
Dual-2 Ohm Subwoofers: 0.33 Ohm
Dual-1.5 Ohm Subwoofer: 0.25 Ohm
can any one explain this diagram a little better? id really appreciate it. thanks in advance.
ea but should i have 3 wires runnin from the post in the box, or one wire and split it up into 3 pieces, one going to vc one, one going to vc2, and one going to the woofer.
You want to go from sub to sub. Linking the + from one to the other. On the final sub you'll have one wire that goes to the amp. Do the same with the -. Vc1+ (SUB1) to Vc2+ (sub1). Vc2+ (sub1) to Vc1+ (sub2), and so on. Kinda like a chain.
Do you have the original W6s or the V2s?
If it's the originals, there are two tabs on each terminal. All you need is 1/4" slide connectors. There are provisions for 2 on each coil. Really easy. Took me about 20min to cut, strip and terminate all the wires I needed and about 20 min to connect everything to the subs and mount them in the enclosure. That's easy.
it really want that hard. but i had to run the vc1 postive to the vc2 + and then the vc2+ to the vc1+ of the other woofer. so on the vc2+ i had to put to wires in one connector. thats what was hard.
spike_e
ballin on a budget
spike_e
prattville AL
benzmansl65amg
