Help with vinyl finish
santafe
I have been going around the internet for quite some time now looking for a guide or examples of how to give the vinyl cover for a subwoofer enclosure some cool finish. My search has so far been in vain, so I hope some of you guys can help me.
What I want is to find out about techniques, tricks, or whatever, to give the vinyl texture, sort of an emboss, to display a name, logo, or simply patterns. How should I approach embossing the vinyl? What do I use under the final vinyl layer to give it texture? Other layers of vinyl?
Also, I'm interested in cool additions you can give to an enclosure, generally speaking, to make it personalized, rather than it being a simple box. I know that fiberglass is a way to do this, but right now I am not considering making a fiberglass enclosure. What I am looking for is for simple to do ideas that make a regular wooden enclosure, covered with vinyl, look cooler.
I've been thinking about embossing the vinyl, placing LEDs, and making a cover that goes over the subwoofer enclosure like this:
Any ideas?
You can use closed cell foam or masonite to create raised patterns. Simply cut the design you want, glue it to the box, then lay the vinyl over it. Use a heat gun to form the vinyl to the design. Try to keep the foam thickness at .25" or less. For embossed patterns you can cut them into the wood with a router or use a thin sheet of masonite with the logo cut out laid over the box . Again, .25" or less otherwise you're gonna have headaches. Trial and lots of error will eventually net you good results.
When laying vinyl over a raised logo that has a letter like "O" or something with a closed center ( P,R,D,B,Q,0,9,8,6)it's best to lay the vinyl over it first, use heat to form the vinyl into the depression and work outward from there. You don't want an air bubble in the middle because you'll never get the vinyl to stick down into the depression.
I always try to do something different each time I build for someone. Key chain neon lit skulls, photograph flushed into surface under Plexiglas, ohm option wiring diagrams routed into side plates, checkerboard vinyl floor with image cut and replaced with opposite colors ( do it carefully and you end up with 2 sets). I posted all these ideas at http://www.gospeedracerx.spaces.live.com.
Very nice.. thanks. I will certainly give that a try soon. I'm probably adding another subwoofer to my audio system this week, and I am looking for cool ideas to add into the new enclosure.
That other idea from speedracer on the skulls looks interesting, I'm considering it.
a simple way to do raised letters would be to use a hot glue gun to create the raised areas. us emore glue then you need and cut away the excess. use a stretchable vinyl and good glue then hold the vinyl against the raied letters with a layer of low to medium density foam and a large weight until it dries.
santafe
santafe
Panama
Symon_say
Mike Mccabe
