help with supertweeters lol
no flaming please. im just looking for some information. ive seen some other people using these eminence apt80 supertweets, and they wire (in the positive wire) a little "cap" thing...looks something like this: http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=027-406
it so if its gonna blow, that little cap thing blows 1st and disables the tweeter. i guess its sorta like a fuse type thing?
again please dont flame, im just looking for what i need to get. tweets are Eminence APT 80
usually caps are put into place to act as a crossover. a resistor can be used to attenuate the output. but i've not heard of using a capacitor as a protection circuit.
can you get a link or picture of the actual capacitor used? our electronic guy has never heard of such a thing. he made a suggestion concerning just running a fuse inline with each tweeter. basicly put, start small, like 2.5 amp, crank your stereo. if it pops before full volume, try a larger fuse. stop when you get to the pointof being able to crank the system where you want it and don't blow a fuse. that way if there is a spike above that, pop goes the fuse and your tweeters are safe.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
- A single cap on a tweeter is a basic 6bd per octave crossover, or high-pass filter.
You would have to research or ask the manufacturer what value you need... they are rated in Micro farads (uf)
They are not really a tweeter protector... it's just that since the cap limits low frequencies, the tweeter sees less power/ less low frequencies. The cap you gave a link to might not blow before the tweeter... those are better quality, possibly higher voltage. The cheaper caps are liable to blow first.
Cheap caps:
http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=72
The caps you use for crossovers must be non-polarized or otherwise listed for crossover use.
When they go, they explode like a firecracker.
Piezo tweeters have a built in mechanical roll-off and oftentimes don't need caps... but a cap can tailor the response and allow it to handle some more power... it's not unusual to see a cap on a piezo.
Those things are made to go with arrays of highly efficient pro mids for far-field use.... they are usually around 100db or more sensitivity at one watt... they are wayyyyyyyyyyyy too loud to be matched with just a pair of car midranges. You'd need a door full just to keep up with the tweeter. Plus, I believe they have higher distortion. Nasty! LOL!
Nothing we haven't told him a bunch of times...I'm just waiting to read the "It's too loud" thread //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
oh you wont hear that from me. like ive said ive heard setups with far more pro audio speakers than ill have and i loved it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i got my 2 selenium compression horns for the cargo area...now those *****es are loud!
lol where have you been, check out my sig, i have 16 mids
pimpedout97x
Tampa, FL
///M5
