Help with Sub and Amp
luischav3z
8
AZ
I've been looking for a cheap amp and sub and came to the Sony Xplod ones. amp is 1000 W and Sub is 1200 W
Are they a good match? I don't know anything about car audio so would these would work great. What do you guys think about this set up?
Any comments are appreciated.
Sony 2/1-Channel Xplod XM-GTX1852 370-Watt Car Amplifier
Max Output Power / Channel Qty: 380 Watts x 2
Crossover: Active crossover
Response Bandwidth: 5 - 50000 Hz
Continuous Power / Channel Qty: 185 Watts x 2
Amplifier Output: 2-channel
Input Signal Voltage: 0.3 - 6V
Crossover Slope: 18 dB/octave
Low Pass Frequencies: 80 Hz
Output Power / Total: 1000 Watt
Distortion Factor: 0.06%
Amplifier Output Details: 185 Watt - 4 Ohm - 20 - 20000 Hz - THD 1.0% - 2 channel(s) ¦ 200 Watt - 2 Ohm - 20 - 20000 Hz - THD 1.0% - 2 channel(s) ¦ 400 Watt - 4 Ohm - 20 - 20000 Hz - THD 1.0% - 1 channel(s)
Sony Xplod XS-GTX120LW 12" Car Subwoofer
Speaker Type: Passive
Speaker Diameter: 12"
Nominal (RMS) Output Power: 350 Watt
Max (RMS) Output Power: 1200 Watt
Response Bandwidth: 30 - 1000 Hz
Input Impedance: 4 Ohm
Sensitivity: 83 dB/Watt
Magnet Type: Ferrite
Connectivity Technology: Wired
Series: Xplod
do not buy sony subs...just buy used if your really on a budget...whats your budget? if you dont want to buy online then go to your local pawn or audio shop and see what they have
What about these onesKenwood KAC-8105D
and
Kenwood KFC-W3012
both from crutchfield
the amp is fine, but buy it from amazon for cheaper price, its only $124 free shipping instead of $199 from crutchfield
Amazon.com: Kenwood Kac-8105D 1000-Watt Class D Mono Amplifier: Electronics
here are three subs choose them, they are better than that kenwood sub in my opinion
SSA Shop - SSA Dcon 12D4 subwoofer300rms
JBL GTO1214D 12" Dual 4 ohms Grand Touring Die-Cast Series Car Subwoofer
Amazon.com: JBL Power P1224 - Car subwoofer driver - 400 Watt - 12": Electronics
if ur wanting matching gear, grab one of the jbl subs and grab this amp
http://www.techronics.com/caraudio_10302_JBL-GTO3501-360W-RMS-Monoblock-Grand-Touring-Series-Car-Amplifier.html
if u can fit a 15" sub, grab this one, its only $108
http://www.techronics.com/caraudio_10299_JBL-GTO1514D-15-inch-Dual-4-ohms-Grand-Touring-Die-Cast-Series-Car-Subwoofer.html
it will give it 360 watts, its rated for 350, so it should do just fine.
u can step up the sub and amp, but its gonna be $352
JBL P1222 12" Dual 2 ohms Power Series Car Subwoofer
http://www.techronics.com/caraudio_10303_JBL-GTO7001-700W-RMS-Monoblock-Grand-Touring-Series-Car-Amplifier.html?aff=72182
u could do this, its 500 rms sub/amp, costs $272
Rockford Fosgate Punch P3D412 12" Dual 4 ohms Stage 3 Car Audio Subwoofer
http://www.techronics.com/caraudio_10240_Rockford-Fosgate-PRIME-R500-1-500W-Max-PRIME-Series-Monoblock-Car-Amplifier-R5001-.html
i havent used prime amp, but i liked my punch amp and punch subs got loud
or u could go with this, its two subs, 1 amp, all matching, costs $316, i know this would be loud, i have these subs off 400 watts, this amp does 500
two of these subs
Rockford Fosgate Punch P2D212 12" Dual 2 ohms Punch Stage 2 Car Audio Subwoofer
this amp
the jbl setup would probably have the better sound quality, imo, still get loud, but the last setup i linked with two 12s will be the loudest no doubt
Ahh cruzer you keep bringing some nicer stuff. I can't decide. hah but thanks
I coudn't find how much techtronics charges for shipping neither if it is free shipping.
luischav3z
luischav3z
AZ
pro-rabbit
